Originally Posted by
F1 Rocket
Stick input teach in should be done on high rates.
And please remember, the system will be reset to factory default (including the mounting orientation) each time you teach the Input Signal. Not a problem if you have the CP mounted in the default orientation which is upright with the connector socket towards the front of the airplane. Any other mounting orientation will need this reset via the software AFTER the Input Signal is taught.
All taken care off. I'll be tomorrow in Melbourne for work so I might swing by the shop to grab some fittings and other things I need. Here's a pic of the final set up.
