Originally Posted by
vwitte
I’d like to replace the carburetor on my Fox .60 Eagle engines does anyone have any suggestions. ?
i heat these engines are very good.
In my early Fox Eagle days I managed to loose my Fox Eagle carb and I made an adapter to use other carbs. I had some inventory from a closed hobby shop and they had a box of OS carbs so I used my adapter for one of the OS carbs and it worked out great. I have found that the Fox 46 ABC (I have 4 of these great engines) uses the same carb so that might broaden your search. The .46 ABC uses two carbs, one air bleed the other two needle and the end result seems to work out the same.
