ok progress so far not that anyone is reading this dribble.
All cabling is completed, relays working as designed.
Next issue is to program the ESC, specifically change it to plane mode and set throttle end points.
At present when I plug the battery in it detects a "throttle", in this case switch is in full throttle position and goes straight into programming mode.
My aim will be to program the switch as follows:
- S0 relays off, ESC not connected
- S1 ESC receives a throttle stop setting & relays are triggered connecting the Lipo and the ESC arms with correct beeps
- S2 ESC receives a throttle full setting and motor is engaged to spin at full power
Hopefully this works, if not it will be use a manual arming switching to trigger the relays or a spare channel on the Tx/Rx to achieve the same.
Plan A, B or C!
