RCU Forums - View Single Post - prop for an 77 mvvs?
Old 11-06-2003 | 11:55 AM
flyn4Him
Default RE: prop for an 77 mvvs?
I think you should be ok with a 12x10, 12x11 if you are using it for pattern. I believe the MVVS 77 is a long stroke so the rpm's should be a kept on the low side etc. 10,500-11,500. You may want to verify this with Morris Hobbies if you are able to. Hope I've helped you some.
In Christ,
Joel Chavez
