RCU Forums - View Single Post - Bird of Time Electric Conversion
Old 12-02-2019, 08:38 PM
glideher
with teh bird of time you must make sure the battery is the right Mah in terms of weight, or else the tail will end up too heavy and throw off your CG, speedracerntrixie might be right a 850 will work work, you wont need too much weight or too big of a motor as you only want to climb up and glide most of the time
