Old 12-20-2019, 02:01 PM
allanflowers
allanflowers's Avatar
Using a foam EDF for testing would be a great idea, maybe along with some simple chuck gliders. A lot depends on whether you would still use the model's existing elevator for pitch or these new canard surfaces (probably the worse option).
The balance of the plane should not vary depending on speed and load, at all. If there is an effect at one speed, it will be there in others too.
