RCU Forums - View Single Post - Syssa engine advice?
Old 12-27-2019 | 12:35 PM
jjohns51
Default Syssa engine advice?
Several years back, I bought an engine (used) that someone (first owner) had some difficulties with. As I understand it there is a bit of a historic thread on this (my) engine. I didn’t realize this happened till after I purchased it. I discussed this with Todd and he happily and very quickly took it from me and did a very thorough going through. He sent it back to me right away, said she runs perfectly now, and almost immediately after, I was shut down from most all of my hobbies. Again, it has been several years, and I have recently been trying to get back into the hobby so I thought maybe I’d send it in for a quick once over before trying to use it for the first time. Apparently this is clearly not going to happen. Would someone be interested in purchasing this from me? If not, and I try and give her a go, is it reasonable to expect that she may run? Or should I expect to change something out? Or is she just a pretty conversation piece? Any responses are appreciated. Thank you in advance. By the way, in case this helps, it’s serial # is 0090799.
