RCU Forums - View Single Post - Tfl bronco toyan 4 cycle build
Old 01-09-2020, 01:35 PM
RAMMJETT
RAMMJETT's Avatar
Default Tfl bronco toyan 4 cycle build
So I have been doing some work on my TFL bronco build , first problem with using a gas engine in a crawler is the transmission does not have reverse . . my solution is mating a axial 2 speed aluminum transfer case with a reverse module from a HPI savage . I needed to make a new input shaft and adaptor plate and a output shaft bearing support ,also needed to make a hub adapter for the spur gear . .. seems to be coming along
