Originally Posted by
BarracudaHockey
Pros for the igyro is the hold mode is implemented better, it releases as soon as you move the stick. Allows GPS input for gain changes due to speed. Con outputs are hard coded, you have an extra elevator slot you can't remap it for nose wheel or whatever.
Cortex you plug in servos and it assigns outputs during the teach-in so its more flexible setup wise but hold mode is only good for torque rolling airplanes.
They both work really well.
OK Thank you. I assume rates can be changed on both in flight via transmitter knob? I don't really use hold, can program for two seperate gain only setting via switch and have off/low/high gain switchable?
