However, there are also some things, that I don't like.
- The wing servos are mounted using L brackets. The same L brackets are used for the gear door servos. With two aileron, four flap and two gear door servos, we get eight in total. However, only twelve L brackets are shipped. I made four more by myself.
- There are two different kinds of hinges for the flaps. Eight of one kind and four others. However, the manual does not tell where they should go. We asked TopRC for advice and they told us that the eight go into the center wing and the other four into the outer wings.
- The pushrods for the gear doors are too short so that the doors don't close completely. I had to replace them with longer ones that I had laying around.
- The springs in the oleo struts are way too hard and too long. My oleo struts did not move at all. I had to replace the springs. When I disassembled the oleo strut, I discovered that the original springs were deformed because they had been mounted using extreme force.
