Originally Posted by
RichardGee
Any idea what oil the previous owner was using and at what ratio?
p.s. Don't mean to sound critical, but I told you to check your valve adjustment. IF your exhaust valves were stuck, you would have found this immediately
You have a point, but in my favor, the valves open the first mm smooth, so I could not notice while measuring in closed position.
No idea on the feul used by the previous owner.
There also comes a dry noise from the camshaft, can I open up the bottom pusher and lubricate this?
