Originally Posted by
ira d
it has been a while since I used my TM8 and I don't remember having to relink after changing the switch but it's worth a try. I have a FrSky FASST compatible receiver that I use with my 16SZ and I dont understand why it
would not work with the TM8 although I have never used it with my TM8. I have semi retired my 9C and use it mostly in the shop to set up systems .
Do you know if you have the 16SZ in FASST-MULTI mode? If that is the case then I guess any Futaba TX than can do FASST-MULTI would work for the non-futaba 8 channel RX's. Or am I missing something?
