RCU Forums - View Single Post - Byron F15c Project
Old 01-24-2020, 10:26 PM
  #167
Eagle Driver
Eagle Driver's Avatar
Yes the gear is the original that comes with the kit
but Catherine from Feibao send stronger rotating pins.
There are absolutely no yaw effects. The turbine is
mounted with a angle from 3 to the centerline of the
fuselage.
This was not the first Eagle i`ve build with the single
turbine setup. They all have no bad habbits or yaw effects.
The big scratch build F-15 that was mentioned earlier in
this thread was also mine and had the single engine setup.
You can see the scratch build Eagle here ...
