Originally Posted by
skymaster68
The Rebel 2m is a super light airplane, I haven’t weighed it but is so light... mine is with a 120 and a 100cc UAT from FCT, the 120 push’s it with authority a friend has the same equipment and running a kt100 it’s also great power, more that enough... we both fly at paved runway at 1650 ft above sea level and temps between 25 to 37* C
Good to know. I'm at around 2700ft where I fly, same temps as you. I will probably buy the turbine last. I have a 140 and a 170 that I can mock up in the plane toward the end to get an idea of final weight. Knowing me, anything over 22-23lbs dry and I will probably want more than a 140. A 160 would only be a $200 difference and 1/2lb weight penalty for almost 5lbs more thrust
