RCU Forums - View Single Post - T-One Models 2.7m F-22 build
Thread
01-31-2020, 06:00 PM
73
FenderBean
I finished the second wing today, im going back a bit showing the hardware per surface to help anyone. I added some extra washers on rod ends for clearance and extra safety, the brass balls pop out pretty easy.
1/2 arms is more than enough for servo throws and it still will probably require less than actually available. The flap servo is the hardest to get in but doable, I manage to put the servo in from the inside so I didnt have to cut the wing root at all.
video is uploading on my youtube channel showing all of this and more.
You Tube
Leading edge flap hardware
Trailing edge flap hardware only thing wrong here is the rod, the rod in the aileron is the correct rod. The Stock is too short
Aileron setup
This glue was preventing the flap from moving at first. Once I broke the glue loose from the hinge I went back with a dremel and cleaned it out. its just extra weight
06:17 PM
Reply
Like
FenderBean
View Public Profile
Send a private message to FenderBean
Visit FenderBean's homepage!
Find More Posts by FenderBean
View iTrader Profile
