Originally Posted by
ledd4u
I have the air system for retracts. Just saw a JP electric set for under $400! JP system but I don’t see to much information on the use of these. Are they not as good as the electrons?
‘First, you do see plenty of info on the JP electric in this tread
if you purchased the T-1 from pacific and select electric retract it will be the JP retracts.
That’s what I had on my T-1 and I now have the Electron to install....that should be happening shortly......and no way the JP will ever be as good as the electron, they are not terrible, but doesn't compare to the Electron....as far as controller and brakes.
