There are no holes for sure I’ve flown on Four different grass sites, but touching down nose high is the trick.
Electrons are the best, but heavier. So more load. In this case I would say I would stay with the JP gear.
Level speed I guess is very similar 45 or 70N but vertical speed with the 70 would be the way to go...and I would think longer flights as full power would be required less.
