Originally Posted by
FenderBean
I know exactly the issues, the left T is 2.97mm and the right is 3.07mm which matches the servo drive unit at 3.07mm
From what David said about his and now you it would appear to be a manufacture issue
After you talked about it I checked mine and the left has a little more play like yours. Will try and figure out a solution. I send a message to the factory on it also so they can try and change what they are doing.
