Originally Posted by
gunradd
After you talked about it I checked mine and the left has a little more play like yours. Will try and figure out a solution. I send a message to the factory on it also so they can try and change what they are doing.
I placed three (3) layers of aluminum tape in the gap to reduce rudder movement. This solution seems to eliminate the excessive movement of the rudder.
simple solution to rudder
