Before I started shaping the blocks, I put in another piece of ply. This one is in the place of the bombardier's window in the nose. With these 2 references, I was able to start shaping. Using a dremel tool with a coarse sanding drum. I set up my shop vac hose on the table and just let it run while grinding away balsa.
