In both views the vertical tail seems to be shielded or blanketed by the unusually shaped fuselage and the big canopy, which both might make for a lot of turbulence. That might render the rudder ineffective, if that is what you are observing (that is too little yaw and not lacking roll effect despite enough yaw).
You could try a canalizer.
