Have removed and disassembled the carb No visible obstructions. O-ring under the carb and both o-rings on the look good, as does the gasket under the stop screw. Soaking the carb parts in alcohol to remove and gummy stuff that may be in there. Going to get a new O-ring for the bottom of the carb just in case. No visible tears or gaps. but I've seen better.
