Originally Posted by
FenderBean
Hey Gun can you explain the light controller? Mine has three leads on it, one say gear signal, one says switch, and the third says control signal for nozzle lamp.
The controller has three large, what appears to be voltage regs and each has two leads/plugs coming from it. So do u plug the slime lights into the voltage regulator leads and the reds/green/landing lights into the pins on the controller?
to funny. I am working on that as we speak lol
i laid it all out on the floor and got it.
yes the nav lights landing lights plug right into the controller. Some of the outputs blink and some are on all the time.
the slime lights run on a different voltage so they have the big resistor and wires.
switch goes to the receiver.
AB goes to throttle. The AB output is the one lead on the output side all alone. It’s spaced out one connection away from the rest.
landing light connection goes to receiver.
