Originally Posted by
gunradd
The new controller will work from 4.5 volts up to a 3 cell LIFE. So no need to use lipos anymore. That was the biggest complaint of mine. I hate having a separate little Lipo just for the lights.
do not use a 3 cell Lipo that will be to much. 3 cell Life is the max.
This controller will easily handle a fully charged 3S LIFE and a 3S LIPO will push it to its limits. The controller will produce the same intensity from a 4.8V to 9.9V. The small button on top is to set the AB ring end point to turn on the light. I am told you move the throttle stick to the position you want the AB ring to come on and press the button. That should set the end point. Also depending on your radio system, if your landing lights are reversed you need to remove the jumper on the controller on the reverse side where the wires come out.
