I agree with you and I will do that soon but right now if I turn on the plane and move trim up, display changes to trim up and ready and the LED turns on on the ECU. I turn off the radio and nothing changes. Other engines I've setup usually show a failsafe on the display at that point and you usually have to setup failsafe in the radio as well. I will take it out when it warms up here and stops raining to run it in the plane and shut the radio off. It will probably work. Just wish the manual was a little more detailed on the subject.
