Originally Posted by
Tip22v
so I picked up my custom aerosol cans today, I asked the guy if he could give me the color codes, he said he did not have any codes because he matches and then mixes the colors by eye! I must say I was a little skeptical so I sprayed the red onto a spare nose gear door when I got home and I have to say it’s so close that my untrained eye cannot distinguish between them
I can’t wait to try it out on a fully prepped surface, probably another nose gear door for starters.
A tip when spraying the final clear cote. You need to ask the paint man to sell you a product called blending agent. Upol sells it. What it does is it melts the sprayed clear cote to the original clear. It’s actually a reducer that when sprayed on the edges of the sprayed clear, it makes it an invisible transition.
https://www.u-pol.com/aus/en-aus/pro...t#.XkYCRLpOmaM
