Originally Posted by
cycross
Great to hear. Means it isn't as bad as feared. I wished the factory didn't hard-glue in the mounting tray on the nose though, would have made access lots easier than what is now.
Looking forward to hear about the engine starts. Thanks for sharing all these!
I agree with this, I thought the same thing about the tray in the nose. I have two rather large motor batteries to, two 5800 ion packs and a 3800 9.0 LiFe pack all sitting on the glued in tray. I put the bag of BBs forward of those in the tip of the nose, so the less equipment weight you have the more balance weight u will need. I dont do pilots either so if you use a pilot it would take very little weight, im hoping 290mm works on the CG, I could remove the weight and possible move a a battery back. Anyway hoping to test run tomorrow and check for heat around the tail section.
