Originally Posted by
Fsttanks
Ref the IR bulb. I use a higher power bulb with slightly smaller dimensions so it was worse. I went ahead and made an IR bulb holder that positions the bulb deeper in the sighting port, not almost sticking out the front of the sighting port like Tamiya had it set up. Fortunately there is good amount room in the mantle to work with.
Yep, you're right. Yours does look great!
