Originally Posted by
clavin
Pump Factor??? What is it you are trying to accomplish? The ECU should already be setup for you ....
These are not ECUs supplied with the pump. This is KingTech Telemetry, an optional accessory. It is not delivered directly to the pump. This means that it is not set to the pump. ***winter***
https://kingtechturbine.lu/KingTech-...-1-Telemetry_1
