Originally Posted by
clavin
It should be fine.. Play with it .. The easiest way is to run 1 liter of fuel and the check to see if the Telemetry unit is saying you burned 1 liter of fuel... Above you said int he "ECU" .. The ECU = Engine Control Unit
Yes, that would be a way to set fuel consumption.
I thought, that is for each turbine / 45, 85, 120,140 .... / some approximate value is given in advance. At this value, the setting could be started. Then just fine-tune. ***winter***
