When I built the plane above I was stil using my 72 mhz system. I now have a 2.4 ghz radio. And yes there still is an antenna . @ actually. Short,just a few inches long. The first part is covered just like a coax cable and only about 2" or so of the inner conductor expose. That is the actual antenna. The 2 antennas are installed at 90 degrees to each other.
The tubes I used to run the 72 mhz antenna in the above plane is still there, but no longer used.
This is what I got done yesterday.
And I found the wings airfoil does not match up with the wing saddle in the fuse. I will have to get an accurate copy of the wings airfoil and transfer that to the fuse wing saddle. Not that big a deal, but that's what I get for assuming.
Ken
