Originally Posted by
winter1
So I have an answer. The default value for the "Pump Factor" setting for the turbine K 140G is 0420. After 3-4 flights will need be adjusted.
The information was sent by JMB-Jets - KingTech Turbines representation for Europe. Thanks. ***winter***
If you are looking for some kind of low fuel alarm, Jeti has an actual fuel flow meter that works really well (I have one). If you want something less expensive ($39) you can use a Jeti MUI current sensor, I use one of these on another jet and find it to be fairly accurate for measuring fuel burned. In both of these jets I have an alarm configured on my DS-24 to alert me when my fuel is low and it's time to land. - Tom
