I just got mine all together after purchasing it used and going through it
Basic empty weight with the CM 1.3L tank is 8.8lb, not adjusted for CG correction although I can shift my ecu pack
Does anyone have the Xicoy CG measurements to verify against hasty eyeball measures? I can't find the thread here that I think Fenderbean started
I measured 450mm between the nose to mains, 25mm between mains and CG mark @145
mm
