RCU Forums - View Single Post - ***CUB BROTHERHOOD***
Thread
03-13-2020, 06:46 PM
4344
bryanmiick
Bob feel free to copy me. the cabin top ribs got sandwiched between aircraft ply and lite ply
the formers will get removed after the fuselage is together. this shows the wires sandwiched between plywood
this shows a piece of brass tube with washers soldered on both sides between the ribs to space the rear of t3he cabin top. this tube will get a piece of all thread with blind nuts on the outside to clamp the rear of the cabin together when the wings are pulling on it.
the cabin front structure. the side wires will get sandwiched to top ribs like the rest of the wires, then they will get fitted inside wood framing.
rear cabin framing, wires are epoxied and soldered in place. aluminum diagonal tube is cosmetic and will get glued in before windows are installed
this shows the all thread and reversed blind nut that provides the rear wing support, I am using 2 wing bolts on each side and the struts to hold the wings on.
Reply
Like
bryanmiick
View Public Profile
Send a private message to bryanmiick
Find More Posts by bryanmiick
View iTrader Profile
