RCU Forums - View Single Post - Royal Zero Kit Build into Rufe
Thread
03-16-2020, 07:26 AM
292
southpaw50
Royal Zero to Rufe Build
More cowl progress...
Cylinders getting first color treatment of airbrushed flat black.
Air-cooling baffles sprayed flat gray.
Edges of cooling fins dry-brushed with Rub & Buff silver for a more metallic look.
Semi-finished. Notice lowest ( narrow ) base of cylinders sport more of a burnt tan color than blue-gray uppers. Base flange already have toothpick "bolts" drilled & glued in place.
This is how it was done, hand-sanded to fit, hand-drilled with 3 successive sized drill bits, glued in from bottom, snipped & sanded......... all 61 of them.
Cylinders getting cemented in place on crankcase core, which has already been painted & weathered to look genuine.
Acetate template to give the illusion of a back row of cylinders ( as opposed to just flat black which just looks like a single row).
Temporarily fitted inside the cowl. Next photo update will show the process of wiring and pushrod tubing.
Reply
Like
southpaw50
View Public Profile
Send a private message to southpaw50
Find More Posts by southpaw50
View iTrader Profile
