Long pause and sorting through items to address are: adding a carry-through tube for the two short wing pivot tubes at the intersection with the long one; spreading out the load for the spar box attach points; keying in drive horns for the flying surfaces; trimming pivot tubes to final length and retention means for the wing panels; sheer web installation, LE/TE install, and sheeting of flying surfaces; servo mounting and installation in the spar box/center section; trimming hinge tube to length and retention means for the fuse hinge knuckle; try stiffening up the aft fuse "C" section with the ramp and tri-stock mentioned at post #31; oh... and should do that once-in-a-lifetime shoveling out of clutter around the house.
Reason: very important addition
