RCU Forums - View Single Post - Hangar 9 F22 Raptor Glow-To-Electric Conversion
Old 03-19-2020, 09:15 PM
  #41
guapoman2000
guapoman2000's Avatar
Okay,
I can honestly say that I almost changed out the motor (Emax BL3526/04) a 860Kv motor with very good specifications that allows up to 5-Cells (18.5 Volts nominal), however, I found a few articles on how to glue back in the lose Magnet from the rotor (rotating bell housing) that contains all of the rotor's magnets.
https://www.google.com/url?sa=t&rct=...-71QEmCs4mYerR
This was possible because after careful disassembly I found ZERO damage inside the motor and inspection was possible using 30X times magnifying glass (Hand held). The Stator's windings at ALL Poles looked great and sounded great on subsequent test run.
After allowing the Gorilla "Clear" Glue to cure all of it's 24-hours as specified per instructions the motor test looked and sounded very good, like new. I am sharing a few pictures of my model's issue with this motor and I will be now going to fly it with the GForce Elite Series 4-Cells, 4000mAH, 30C Lithium Polymer packs.
