It has good compression. I removed the spark plug and it was... damp I guess you could say. Not enough to be flooded. The choke is working, it pulls fuel from the tank. As far as hearing "normal" intake sounds, I don't really hear anything there, just the sound emanating from the spark plug hole.
i haven't been able to see anything, but is it possible I have a crank case leak that would not allow enough pressure differential to operate the pump?
