Sorry for not updating during this quarantine im just trying to get as much done as I can In my life right now. So for I took apart everything (except the rear end) , cleaned it and removed the electronics out. Right now the chassis is in 3 pieces. I cleaned it with soap and water then sprayed everything with wd40, I had to use bike grease that I had for all the metal stuff. So far I didn't notice anything broken or out of place the only thing I noticed was a lot of dirt. Actually I did notice something, the front shocks had little to no oil in them.
Once I was done all of that and i put it back together i started making a list on stuff I know for sure im going to need.
-Shock oil
-servo
-reciever and transmitter
-Also to test the electronics i have and see if they work.
So now im going to work on cleaning the centre chassis and then disassembling the rear end, cleaninig it and rebuilding it like the front end then I can put it together and I should be done with the rebuild and should have a roller with no electronics installed. Then I can start sorting through the extra parts and see if I can make another roller out of it.
