Originally Posted by
Hydro Junkie
How old is it? Anything prior to roughly mid 1991 is not legal due to being wide band. I have a 1988 Conquest 4 that I can't use for that very reason.
Not exactly illegal, more a case of unsociable. The wider band receivers will be inclined to respond to anything thansmitting on adjacent channels, the wider band transmitter is likely to cause interference to any receivers on adjacent channels. I have a vague feeling that Futaba were working to the tighter standads before the powers that be mandated the present narrower bands. So the only real problem might well be the actual band of the set - if it is an air only band, no it should not be used for surface.
