RCU Forums - View Single Post - 3200 mah and 5000mah in eflite apprentice
Old 04-01-2020 | 07:41 PM
jester_s1
Moderator
You probably won't save any weight going below the 3200 since you may wind up tail heavy with a lighter battery. I'd not mess with it. Slowest possible speed is not a good goal for a trainer plane since too floaty is way worse than too fast. Also, you'll be cutting flight time which hurts the learning process. 8-10 minutes is about right for a training flight.
