Originally Posted by
FlyerInOKC
I was thinking it might be the Nieuport 27 I know the pilots didn't like it but they loved the Nieuport 28.
Sir; not the Nieuport 27. But I will award a bonus clue for your effort, along with an afternoon clue. Keep trying. Hint: When you find the right answer, you will almost certainly say "Okay; that fits. And it should have been pretty obvious". Thanks; Ernie P.
What warbird do I describe?
1. This aircraft was, by all accounts, a perfectly acceptable combat aircraft.
2. It was, in fact, probably superior to any enemy combat aircraft of the same type and flying at the time.
3. It was, however, always compared unfavorably to another aircraft of the time.
4. The other aircraft was flying at the same time; and flying for the same side.
5. And so our subject aircraft became the “ugly sister” to the preferred aircraft.
6. Still, significant numbers of our subject aircraft were produced; although not nearly as many as the “preferred” aircraft.
7. The pilots who flew both were almost universally adamant in their loudly voiced preference of the other aircraft.
8. And, they made their voices heard.
9. Although at least two pilots preferred our subject aircraft.
10. And, since one of the two was very well known; and part of the selection team; the authorities produced our subject aircraft. Which gave him the opportunity to fly our subject in combat.
11. However, I can find no record of this pilot actually flying our subject aircraft in combat.
12. He did, however, score a number of victories while flying the “preferred” aircraft.
13. Like everyone else, when he had a choice, he preferred to plant his backside in the other aircraft.
14. Our subject aircraft could dive even faster than the preferred aircraft.
15. And could at least match it in level flight.
16. But our subject aircraft was usually referred to as being heavy or clumsy on the controls.
17. While the preferred aircraft was light, quick and seemed to respond faster to control input.
18. And it almost seemed to anticipate control inputs.
19. The comparison of a plow horse and a race horse seems appropriate.
20. Delivery of our subject aircraft was delayed by difficulties with the cooling system.
21. Even so, from first flight to first delivery to the field was only a matter of four months or so.
22. The design of the wings was openly copied from a foreign design.
23. One noted for being very rugged, and able to dive without any fear of the wings folding up or being damaged.
24. And one specifically noted by our subject aircraft’s military air service as being well designed.
25. In fact, our subject aircraft was created, in a sense, by combining that copied wing with an earlier aircraft from the same factory as our subject. There were some changes made as testing progressed, but essentially our subject was created thusly.
26. The airfoil section was rather thin, as was the wing that was copied.
27. Our subject was criticized as having an abrupt stall, as were most planes in those days; the preferred aircraft being the exception.
28. Our subject needed a long takeoff roll, as compared to our preferred aircraft.
29. And it had a tendency to “float” when landing.
30. Which, given the landing gear was considered to be weak, created problems.
31. The ground crews disliked our subject aircraft because, when compared with the “favored” aircraft, our subject required much more maintenance.
32. Mostly because of all the bracing wires; which were missing on the preferred aircraft.
33. Some of our subject aircraft were captured, and tested, by enemy flying services.
34. The results of this foreign testing pretty much confirmed the opinions of the host nation’s flyers and ground crews.
35. And yet, there is still no doubt our subject aircraft could handle pretty much any enemy aircraft put up against it.
36. That was also noted by a number of aces who wrote about our subject.
37. In its short service life, perhaps five months or less, more than 800 of our subject aircraft were produced.
38. It was also the last aircraft of this manufacturer to see widespread service.
39. Unlike its predecessor, by the same manufacturer, this aircraft used a conventional front mounted radiator.
40. And, again unlike its predecessor, it used two bay wings.
41. The first 200 or so examples produced had a different layout of the tail surfaces; much sharper and more rectangular than the final version, which was much larger and smoother.
42. The earlier aircraft referenced in (39) also featured rather smooth and contoured tail surfaces.
43. The “favored aircraft” is generally considered to be iconic.
