Ok, I am back with a question or 2. 1 Which is the best glow plug for radials? I am using OS F. When I remove the igniter from the plugs, the engine starts to bog down.
2.Did you find the adjustment on the high end needle very sensitive? the range at which the engine runs fine is very small, 5 or so clicks.
