Originally Posted by
smittymgs
Hey Guys
Finally got around to starting my T1 build. Started on the wings and just a heads up. While installing the wing servos the servo hatch fell apart. Bad glue joint between the servo hatch and it’s internal structure. The counter shrunk screws pull through and will not hold the internal structure and servo in place. If this happened in flight best case you would lose that aileron or flap, worst case flutter or airframe loss. I re-epoxied the hatch and internal structure ,used larger washers instead of the counter shrunk screws ( it’s on the underside of the wing and I don’t care) to make sure it holds. Might be worth checking
Hello.. Can you send me photos so we can have this addressed at the factory? I would wic thin CA around the frame work to make sure they are all secure.
Jeff
