Hi
P-47 are normally ok. Watch the yaw on take off as it will want to pull to the left. You will probably need a fair bit of rudder to keep it tracking straight. Let the tail rise and balance it on the elevator, try not to pull up elevator to early. Hopefully it will will rise gently into the air.
once it’s in the air they fly like any other. Keep the elevator inputs smooth and you should be fine. Check the flaps in flight but to be honest all the p47 I have had land well with or without flaps. Good luck with it hopefully you will love it
