main problem with painting the outside of any body is there will be no protection from surface scratches... however if this is just going to be a shelf queen, then simply spray several layers of clear coat on top to get a nice glossy finish...
for example if you want a bright candy-apple red, then you want to paint the body with solid white backer first, then your candy color, then several coats of clear to make it pop.
