Originally Posted by
flygono
Thanks Tom for the information but before sending the engine I noticed that the rear cylinder spark plug is not firing. I exchanged the spark plug an it's not the culprit. It's either the Electronic ignition module or the cable/spark plug boot.
Does any one know how how to tell where the problem is?
If not where can I get a new ignition module? I did a Google search for Gunter Muller ignition but could not find it.
if your ignition has the Müller sing, it’s pretty old. Kolm bought the ignitions and modified the Lay-out inside. You can send your ignition to Simon. Maybe he is able to repair it. If not , he will order a new one for you.
please send also the sensor cable.
Tom
