Use acetone and the strips included to glue the cowl and pants together. You need top open the wheel openings first so you can place the strips inside. Make sure the seams are tight before gluing or it will seep out and damage the exterior, and don't use too much, just like thin CA, a little goes a long way. The acetone melts the plastic together much like plastic models glue does with models.
