Originally Posted by
DEMONjoe
David, that's another option, but you then loose the gyro-controlled 2.4 backup, which means that every time the primary fails, the CORTEXpro will switch to the 90MHz rx and not to the other 2.4GHz rx, which may still be ok and "connected". And this, as far as I heard, will change control feel at least a bit via the 900MHz. So I would prefer the upper setup over this version.
The perfect solution will be the one to hook up the 900 rx to one of the 2.4 rxs, all signals at any time running through the CORTEXpro. Lets hope the rx firmware will be ready to do so soon.
Does anyone know if the solution mentioned above was ever implemented? I've got two R3 rx, one 900 MHz, cortex pro, and CB200. I would like to be able to connect the 900 mhz rx to one of the R3 rx, then connect both R3 rx to the Cortex Pro and on to the CB200. This would provide gyro stabilization regardless of radio path. Thanks, Tom
