Took me two days to clean up the mess, Connectors for flaps and Ailerons were soaked with Kerosene
and I tossed them. Made up new connectors purchased from Hansen Hobbies. Servo leads were
cleaned with Windex and isopoll alcohol. Servos leads cleaned up good.. No residue left on leads
For the fiberglass I first wiped it with alcohol and then liberal coat of K2r. Next step took a tootth
brush to the affected areas and let dry overnight. Next day I vacuum the white residue and followed
up with heavy application of isopoll alcohol. The wood is tainted with Kerosene and will not come out.
Turbine had Kerosene all over it,
Crack started on bottom front side of tank and was aprx I inch long. Cleaned
outside of tank with lacquer thinner, Sanded with 60 grit. and covered the seam with 2 layers
of 4 oz cloth. Epoxy was West System.
Saturday hopefully get my second flight in, Jets Munt 80, Jeti 14 transmitter, Smart fly regulator and
12 channel receiver with gyro.
